Old 03-29-2008, 09:12 AM
MEvang's Avatar
MEvang MEvang is offline
MEvang's Photo Albums
Last Online: Today 07:45 AM
MEvang will become famous soon enough.
Default Re: Bleeding Brake Line Question
Originally Posted by Ltning/QC10nomas View Post
Since you know there is air in the front lines would you not bleed those first then the back until fresh fluid comes out then back to the front?
Just asking cause I guess that's how I've always done it as it seemed reasonable?
Your right, you must treat the system as to separate systems. Even if the master had emptied on the front side there should be no air in the rear side. Starting bleeding in the rear with a dry front could damage the master cylinder.
In this case the best procedure is to fill the system. Open the front bleeders and gravity bleed the fronts. (watch for a good solid drip of fluid from each caliper) Close the bleeders and bleed the right front and then the left front. Bleed the rears out to change the fluid last.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
