Thread: Navigation
Old 03-29-2008, 10:25 AM
LGL002's Avatar
LGL002 LGL002 is offline
LGL002's Photo Albums
Last Online: Yesterday 09:57 AM
LGL002 is on a distinguished road.
Default Re: Navigation
Originally Posted by Steve 726 View Post
Is it diffucult to check to see if the navigation antenna or plug is secured properly.My system is a little screwy and the clock didn't automatically change when we changed the clocks a few weeks ago.Trying to avoid the trip tp the dealer.
If the 06 Avalon antenna placement is like our 2003 Camry the antenna will be located just under the rear package tray at the left side and is visible from the trunk. You might want to double check in your navigation settings menu that the daylight savings setting is set to the on position. Also your signal strength will be higher if there's not an object over it on the package tray.
Maybe another Avalon owner with a newer model than our 03 Camry will pipe in with more info about just where your antenna is.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
