03-29-2008, 01:27 PM
amoberry
Re: Corsa Sport Split Side Tips Adjustments
One suggeston about the split side dual tips if you buy the Corsa split dual side exhaust and have someone install the exhaust for you. Once home, adjust the tips the way you like. Since tips are oval in shape and not round, you can get totally different looks with different tilts and/or direction installed. Just loosen the clamp and have some fun. Installed level, they look round from the rear. The more you tilt them down, you get the "fatty" look. Rotate them all the way around and you get sort of a rear exit look. Corsa put their name on top and bottom so does not matter or look wrong either way. Just your personal preference. I adjusted mine with about a 10 degree tilt down which makes them look in line with angle of the exhaust pipe they are connected to and slightly non-round from the rear. Then play with how far they stick out. Flush with outside edge of tire, etc. Mine's in line with 1st outside rib on rear BFG RT tire. No right or wrong answer. Easy and fun.
2007 Tundra TRD DC 4x4, 5.7L, auto, power seat, Corsa Sport split dual exhaust, back-up camera, auto-dim rear mirror, SS running boards, tinted windows, TRD sway-bar, Husky liners, 3M paint film, audio system (Pioneer FH-800BT receiver, Alpine: SPR-17S & 17C speakers, MRP-F550 amp, 10" type S subs), Premium 1 bedliner, Lorado tonneau, bed mat,18.8 mpg w/HCF out, 37/34 psi & 275/65/18 BFG R/Ts, Stebel horn + 2 stockers
