Re: rear airbags question
No you won't need a spacer . Because the space between the axle and frame stays the same . The 1.5" lift is between the top of the axle and the bottom springs .
Air bags can help the rear end of your truck with handling . But it will lift the back even more once you have enough air in the bags to stiffin the ride and improve your handling .
If you aren't going to carry weight in the bed or tow a trailer . I would go with the sway bar . But if you do haul bigger loads or tow a trailer i would get both if money is no issue .
Double cab long box 4x4 5.7 L slate grey . would have bought a limited if available with long box
