Old 04-01-2008, 12:36 PM
DanielAcosta's Avatar
DanielAcosta DanielAcosta is offline
Last Online: 11-06-2009 08:07 AM
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: BFG vs Nitto vs Toyo vs Cooper
Toyo AT and Nitto Terra are very similar though not identical.
I swapped BFG AT for Toyo AT because Toyo made the oddball size I wanted and Nitto didn't. The BFGs were good off-road, poor on snow and ice imo. Doing my first off-road trip with the Toyos this weekend.
The Toyos are definitely better than the BFG AT on the road. Both a 10-ply tire, but the Toyo has a better ride and much crisper steering response.
If BFG made a 285/75/18 I would have tried it. Overall I thought the BFGs were good, but my initial impression (3,000 miles) is that the Toyos are better.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
