Re: Rides Like a BRAND NEW Truck!
Did mine without C-clamps. Center pin lined up and tightened with no problem. Of course, the U-bolts are what really holds it all together, so the center bolt is just an alignment aid.
No squeaks, but haven't taken it off-road yet.
There is one short section here in AZ that mimics I-10 in southern California with bed bounce, and the ride with the mini-pack is amazing. As someone posted early in this thread, I still have a firm TRD ride, but the unbearable harmonic commonly called bed bounce seems to be gone. Over my short test section in AZ I can now hold a drink without it spilling, whereas before it would be difficult to talk the bounce was so bad.
I will be off-roading this weekend to give it a good workout, and taking it to southern California the following weekend for a final test on I-10. Stay tuned.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift ( http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack ( http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
