  #27 (permalink)
Old 04-02-2008, 11:27 PM
DanielAcosta's Avatar
DanielAcosta DanielAcosta is offline
Last Online: 11-20-2009 10:15 AM
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: BFG vs Nitto vs Toyo vs Cooper
Originally Posted by Jhanfosho View Post
How did your BFGs wear? How many miles did you get out of them?
My BFGs wore well. They were half-worn with 20K miles. One had an unrepairable nail hole. Discount Tire worked a deal where BFG paid for half of three and the DT certificate paid for the one that couldn't be repaired. I took advantage of the opportunity to get the taller Toyos, which I wanted for off-road ground clearance.
The Toyos have noticably quicker steering response on the highway than the BFGs did. The wider BFGs had better grip on lower speed (20-30 mph) low traction corners.
I only have 3K miles on the Toyos, but so far I like them better than the BFGs. Still, I wouldn't hesitate to recommend the BFGs to anyone as long as they understood their limitations.
If the Toyos wear as well as others have reported, I will probably choose them again when it's replacement time. Other tires on my short list are Dick Cepek and MT 305/70/18.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
