Re: Dash lights not working...and all fuses are OK
Originally Posted by dude!bro!tundra!
So I installed the Sirius FM transmitter into my 2006 Tundra DC today, and while I was wiring into the factory JBL head unit I shorted out the dash lights and navigation dimmer (basically everything that turns on when you turn the lights on). I replaced fuse #45 (Panel 7.5A), which solved my navigation problem (it now switches to night mode when I turn the lights on). However, the dash lights are still dead, and I have tested every single other fuse with zero success.
Has anyone experienced this before? Is there another relay/fuse that is hidden somewhere in the dash? Doesn't seem likely, but I'm out of ideas at this point. Any suggestions would be awesome.
Well on my 07 I did something similar. Now I bet are trucks are different to some degree but in my case the same thing happened. My first stupid mistake was wiring up stuff with the battery conected, will NEVER do that again.
Turns out the short fried a relay that is in the insturment cluster, one that is also tied into the odometer, which makes things even more tricky (read expensive) Dealer had to order a new cluster, which has to be pre programed by the manufacturer (dealer can not do it) for your current mileage. This is what happened to me at least. They changed the cluster and its fine now.
 2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Pioneer 10" sealed sub box, Clarion 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
