Originally Posted by GGWOODY
I might just do 2 horns... EDIT: Nevermind, I just bought a second to wire up...just for sh!ts and giggles. A little bit more wiring, but hey, the weather is getting nicer, so not a bad project. You think I could run them bith through one 60A fuse? I don't see why not...would do two separate relays one connecting to each of the OE horn wiring.
I love loud
The relay's are 30 amp relays so you will need (2) 30 amp fuses. It should be really easy though. Just pull a single suitable gage wire from the positive battery terminal over to the middle support in front of the radiator. Tie the (2) 30 amp fuses into this single wire and then wire from each fuse to each relay. Then wire from each really to each horn and then from each horn to ground. Then cut each OEM horn wire and connect to its respective relay. You can always reattach the factory connectors and remount the factory horns if you sell or want to put it back to OEM.
