Old 04-08-2008, 10:08 AM
millsp's Avatar
millsp millsp is offline
My eBay millsp's Photo Albums
millsp will become famous soon enough.
Default Re: Need A Little Help With My Electrical System
Your stock electrical system should handle your setup just fine. Be sure to use quality cables and wires and use the correct gauge power wire as stated in the AMP manual. Make your grounds as short as possible and avoid using seat bolts as ground points. Fuse everything and put your fuses as close to the battery as you can.
If interested in the Big 3 mod just Google it. There are tons of tutorials out there on how to do it.
