Re: tunrda battery question
Did they check your battery to make sure it was bad and not just drained from a failing alternator? Maybe your alternator is not charging correctly...
Im not a expert or anything, but I would try turning everything on (example-lights, airconditioning, stereo max volume, turning your steering weel all the way to one side, etc..) and see if it stalls and check the voltage at the battery with a DMM and make sure it's not dropping significantly.
