  #127 (permalink)
Old 04-11-2008, 01:08 PM
blaster21996 blaster21996 is offline
Banned
Last Online: 05-19-2009 10:56 AM
blaster21996 has little shameless behavior in the past.
blaster21996's Photo Albums My eBay
Default Re: New Stebel 300 Hz Truck Horn
I installed one yesterday. Here is what I did.....
I removed the factory horn on the drivers side. Then removed the flat bar from the horn and put in a vice, I then bent the flat bar in to a an offset, so the new horn will be located further under the crossmember it is atached to. I then clipped the factory plug of the hot wire for the factory horn and put on a standard female spade connector and connected it to the (+) terminal of the STEBAL. I then took a 8 inch peice of 12 guage stranded wire and put a female connector on one end, then on the other end I used a standard eye connector, I connected the spade end to the (-) side terminal of the STEBAL and the other end to the mount bolt of the STEBAL to ground it out.
I then upgrades the factory fuse from a 10a to a 15a fuse...... all done!
