  #132 (permalink)
Old 04-11-2008, 02:41 PM
brow's Avatar
brow brow is offline
Last Online: Yesterday 10:24 PM
brow is on a distinguished road.
brow's Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by blaster21996 View Post
I installed one yesterday. Here is what I did.....
I removed the factory horn on the drivers side. Then removed the flat bar from the horn and put in a vice, I then bent the flat bar in to a an offset, so the new horn will be located further under the crossmember it is atached to. I then clipped the factory plug of the hot wire for the factory horn and put on a standard female spade connector and connected it to the (+) terminal of the STEBAL. I then took a 8 inch peice of 12 guage stranded wire and put a female connector on one end, then on the other end I used a standard eye connector, I connected the spade end to the (-) side terminal of the STEBAL and the other end to the mount bolt of the STEBAL to ground it out.
I then upgrades the factory fuse from a 10a to a 15a fuse...... all done!
No relay?
'07 Pyrite crewmax LTD "B" package w/ 18" wheels (BFG 285/65R18 A/T KO) - Purchased April 30/07, hit 100,000kms on Sept 2, 2009. AFE CAI, ARE canopy, hunter bullbar (careful) and running boards, TGC 2.25" front leveler, & husky liners. Air Lift 57299 Air Springs. Front diff changed.
'07 USA market Honda Odyssey EXL-RES imported to Canada (sorry Honda Canada, this one reads MPH)
