Originally Posted by got wake?
well i'm concerned with the physical mounting of the new horns. they are definitely a lot heavier than the stock ones, and since i upgraded to two loud a@@ horns, i want them pointing out, not down  i grabbed some .025" shim stock and bent it to see how well the horn would fit facing forward. well it works quite well:
i'm going to swing by ace hardware and see what i can find to easily fab some brackets up to securely mount the horns. i'll post some more info later.
The box recommends some angle down to prevent water from going into the horn. You might leave it the way you have it but I would install the intake tube with the adapter provided. Water into the intake is alto worse than water coming out of the horn.
