  #189 (permalink)
Old 04-13-2008, 07:59 AM
got wake?'s Avatar
got wake? got wake? is online now
Last Online: Today 04:26 PM
got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor.
got wake?'s Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by blaster21996 View Post
I installed one yesterday. Here is what I did.....
I removed the factory horn on the drivers side. Then removed the flat bar from the horn and put in a vice, I then bent the flat bar in to a an offset, so the new horn will be located further under the crossmember it is atached to. I then clipped the factory plug of the hot wire for the factory horn and put on a standard female spade connector and connected it to the (+) terminal of the STEBAL. I then took a 8 inch peice of 12 guage stranded wire and put a female connector on one end, then on the other end I used a standard eye connector, I connected the spade end to the (-) side terminal of the STEBAL and the other end to the mount bolt of the STEBAL to ground it out.
I then upgrades the factory fuse from a 10a to a 15a fuse...... all done!
the stock wiring is what, 16 gauge? that equates to much less than 300 circular mils per amp, which gets into the dangerous range. 8 feet of 16 gauge with 18 amps passing through it = about 144 cir mills / amp. i've replaced enough wiring in peoples' cars from improper wiring/crappy blue headlight bulbs to know that i won't skimp on wiring. the fuse is not for the device hooked on the other end, it is for the wire going to it. i would highly advise against just hooking the stock wire to the new horn. electrical fires are not fun...
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
