Originally Posted by alexisd
I leave the stock wire from the stock horn to the new relay,that's ok?And then use in line 30 amp fuse and replace the 15 amp fuse for a 25 amp fuse is ok?Oh all wire with 12 g wire.Except the wire from the stock horn.You guy's think is fine,sound good.
Yes, stock wire goes to new relay.
What 15A fuse are you replacing for a 25A? (the 'HORN' fuse on the OE fuse block is a 10A) Use an in-line 20A fuse on your hot wire going to the relay, just to be on the safe side (the packaging recos it, and if you can use a smaller fuse without blowing it, why not?)
