04-13-2008, 12:55 PM
Re: New Stebel 300 Hz Truck Horn
Originally Posted by got wake?
pulled out my old cheap ratshack meter today and measured the horns. one horn measured 114 dB and two measured 117 dB at the same distance. so to reach nearly double the volume, we'd need at least 8 horns (9 dB increase). 10 dB's equates to double the volume.
i might try hooking up the stock horns as well tomorrow to see how it sounds. two stebels plus both stock horns = really effin loud
Just wanted to make a correction... a 3dB increase = approximately double the volume (1.99526 to be exact), not 10. So, in fact you already are getting double the volume since your increase was from 114 to 117 dBs...
07 Tundra CrewMax 4x4 SR5 Silver Sky Metallic is here!
