  #213 (permalink)
Old 04-13-2008, 08:16 PM
got wake?'s Avatar
got wake? got wake? is offline
Last Online: Yesterday 09:34 PM
got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor.
got wake?'s Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by awesomebase View Post
Just wanted to make a correction... a 3dB increase = approximately double the volume (1.99526 to be exact), not 10. So, in fact you already are getting double the volume since your increase was from 114 to 117 dBs...
it is best to not try and correct someone unless you are 100% sure you are correct decibels are logarithmic, so a 10 dB increase = twice the volume. but what do i know, i've only competed in stereo competitions since i was 16 (11 years now) and was an IASCA judge for several years as well
Originally Posted by mxsjw View Post
Another correction...
A 3db increase requires twice the power and is only an incremental adjustment in perceived loudness - 9-10 db is considered 'doubling' loudness.
Many get this confused, and most manufacturers use that confusion to sell products.
that is correct. a 3 dB increase could require the same power with double the drivers (in reference to speakers). speaking from a subwoofer perspective, if you where to double the number of subs and doubled the power supply (second amp, or an amp that is twice as powerful), it equates to about a 6 dB increase. however, those are only generalizations. the higher you go, the harder it is to increase the loudness/dB's, since it is not perfectly linear.
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
