  #70 (permalink)
Old 04-14-2008, 10:20 AM
RONE's Avatar
RONE RONE is offline
Last Online: Yesterday 10:45 PM
RONE is a splendid one to behold. RONE is a splendid one to behold.
RONE's Photo Albums
Default Re: So I got in TRD's 5.7L Sequoia today...
Originally Posted by TRDatVT View Post
This is not necessarily true... think of it this way... take two different straws (one from hardy's and one from mcdonalds). Sorry if this sounds stupid but its a good example and applies to SOME applications but shows the point well. Take the mcdonalds stray which is small, by about half... seal your lips around it and in hale. It provides steady somewhat controlled flow with SOME restriction. If you take the larger straw (hardy's for example) and do the same thing, you can't get a steady stream that feels controlled since you are moving less air than the orifice is made for. This can create inefficiency in the intake portion of the system.
That's not proving what you think it is. The reason you can't get a constant flow through the larger straw is because you can't create a consistent lower pressure in your lungs. An engine doesn't have that problem.
