Originally Posted by Stanton49
One thing I don't much care for is the half-a55ed "intercooler" setup. There is no way running the air past a 2 inch wide cooling jacket/fins can reduce its temperature by any significant amount. Time and cooling surface contact are always an important factor in any cooling process. The air simply doesn't have enough time or surface contact in that jacket to reduce in temperature in a 2" gap. If you guys believe that then I have a little gas saving device you might be interested in called an Engine Tornado.
It's a supercharger, not a turbocharger. Lots of applications don't even run intercoolers with superchargers because they don't heat the air too much at low boost levels (ie 5-6psi).
