Originally Posted by Stanton49
As a previous poster has mentioned, superchargers don't significantly reduce air temperature, so for some applications and some different supercharger types, intercoolers are useless. As for the type of intercooler discribed (with pictures) in the first post of this thread, it will be even less useful then a typical intercooler because it lacks contact area and in-contact time to achieve any significant cooling.
Now if there is intercooling piping beneath what can be seen in the pictures, then it might be effective, but from every angle I look at them, all I see is a 2" wide flange between the air filter outlet pipe and the engine inlet pipe.
I think what you're looking at is the throttle body coolant lines, not intercooler lines.
If you look at the top, back of the supercharger, you'll see two hoses coming out. I'm almost certain these are the intercooler water lines. My guess is that the intercooler sits right in the middle of the big black box. The supercharger sits below it and the compressed air passes upwards, through the intercooler then back down the sides of the box into the manifolds.
