Re: 2000 Sienna XLE: broken rear sliding door handle
Mine just broke yesterday. After using a ratchet drive to remove the screw, I discovered that the cupholder pops off so a regular screwdriver or drill can be used. But I have a 2001, don't know if that makes a difference. The part cost me $95! Could only get it from the dealer, no one else stocked it. Stinks! I will install it tonite and let you know how it goes. Last year I had to fix the rear door handle using a method I found online in which a screw is inserted into the broken pieces and held together. Took an hour, but I did not have to buy a handle for it. I wish that same guy had a fix for the sliding doors! I cannot believe Toyota has not replaced plastic, high use handles with something more durable...I guess that is why the new vans have remote electronic entry. I would hate to see the price on replace one of those motors!
