Old 04-21-2008, 02:53 PM
Mtrosclair's Avatar
Mtrosclair Mtrosclair is offline
Mtrosclair's Photo Albums
Last Online: 11-15-2008 12:18 PM
Mtrosclair is on a distinguished road.
Default hitch installed on dcsb sport
First a look at the beast, class IV ultra frame by draw tite. 84 pounds by itself.
first you remove these little angle brackets, save the bolts they are important!
Next get that bad boy up there, I used a two by four and a jack, this is when you find out that the bumper has to be trimmed and the wire harness needs to be moved. Remove the bracket for the trailer plug first if you want to remain sane. A utility knife works pretty well for the trimming.
Here we go, mounting the plug took longer than the hitch install. Toyota does not give you much wire to work with so thats about where the plug has to stay.
You can make a difference---> http://www.carboncreditkillers.com/
"The tyranny of Murphy is the penalty for hubris."
