  #17 (permalink)
Old 04-22-2008, 11:12 AM
LifeTech's Avatar
LifeTech LifeTech is offline
Slummin'
LifeTech's Photo Albums
Last Online: 09-28-2008 11:38 AM
LifeTech will become famous soon enough.
Default Re: Total Coolant Flush Highlander V6
[quote=DrRuckus13;994242]
Originally Posted by kathyricks View Post
but all this trouble could have been avoided in the first place if you had simply refilled with the factory original (red) type coolant the first time you drained the radiator.
quote]
Geeze... I just did what the Toyota Parts guy told me to. He said use pink it was better and lasts 100K. At the time it never occured to me there was still old fluid trapped left in the block.
but thank you for setting me straight.
The LL Red and SLL Pink are different formulas. The Pink can supercede a Red. But as we can see now, one should completely flush out the Red (with Distilled water) several times to remove any traces of the Older RED.
Be advised...it only takes one introduction of Plain tap water to corrode the cooling system. Then all that corrosion and muck yu find down the road is the resultant affect of this "wrong procedure".
Mixing Red with Pink would not be the direct cause of excessive corrosion.
