Old 04-22-2008, 07:36 PM
LifeTech's Avatar
LifeTech LifeTech is offline
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Default Re: Lost keys.. 84' Toyota truck
Originally Posted by ToyPartsGuy View Post
Can't make one by the VIN on a truck that old. No way. But you can pull the key cylinder from the (PASSENGER !!!!!!) door and it has the key code stamped in to it. Take the cylinder with you and they can test the new key in that cylinder before you leave the Parts dept.
I Agree with above post.
A far as I know, this is the way it has been done for years.
BTW, if yu ever discover your Pass. door key cylinder pryed out and missing with no other damage or theft to your car...be prepared to re-key all the locks including the ign. key cylinders.
Yu are being set up for a car theft at some point!
Thieves will get that key code off the cylinder and make a copy to steal your car when convenient.
But as of late yu need the original chip key to start most cars .....unless yu had one of those AFTERMARKET remote engine starters installed. Then your Chip key is always disabled. Any cut key will work without need to program the chip like the original.
LT
