Originally Posted by Jumbo Jet
Mine had the gap also on the right "A" pillar when I first began this post. Once I stuffed the folded up felt up underneath the dash lip, it sat fine and lined up perfect, plus fixed the creaking noise. You push it up from under the glove boxes while lying on the floor. There is a huge hole there that goes all the way to the top. Takes all of about 1 min.
Jumbo, I've got the creaking/popping dash as well... I just want to clarify a few things:
1. My passenger side dash doesn't quite line up at the bottom front corner of the A-pillar. The dash (black) is about 1cm lower than where it looks like it needs to be on the A-pillar (white). Is this the same situation you had? Did this actually line up perfectly after you did your fix?
2. Thanks for the photos, they help a lot. I tried to reach up there the other day to see if I could feel what you were describing, but all I found was something that was REALLY farking hot... Most likely the heater core inlet pipe. I'll try again when I have a bit more time (and when the truck is cold). My question is: how big is the gap you have to fill? or, how much material will I need to stuff in there?
3. From what you have said, I understand that the rattle fix also has the side benefit of the dash alignment fix. I want to make sure that this isn't done in two different fixes, so I don't have to contort myself under my dash more than once.
Thanks again for the excellent info!
