  #312 (permalink)
Old 04-25-2008, 12:20 PM
got wake?'s Avatar
got wake? got wake? is offline
Last Online: Yesterday 09:36 PM
got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor.
got wake?'s Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by Canadian_Yoda View Post
Mr. Wake,
Have you noticed anything like this with your setup? I haven't received mine yet, but if I recall correctly, the Stebel is fused at 20A? I wouldn't expect a load like this to have a noticeable effect...
Thoughts?
i honestly haven't honked the horns at night, so i can't say for sure. but an instant 20 amp draw *could* cause enough of a voltage drop to see the light difference. a very slight change in voltage can be very noticeable. the tunda has a pretty good charging system, but you can even see the lights dim slightly when you hold the window roll up button after they are all the way up. the reason why i was asking about how it was wired is because if the wire is too small or it is not grounded well, there will be an increased current draw due to the increased resistance in the wire/ground.
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
