  #318 (permalink)
Old 04-25-2008, 02:32 PM
got wake?'s Avatar
got wake? got wake? is offline
Last Online: Yesterday 11:20 PM
got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor. got wake? is a superior contributor.
got wake?'s Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by brow View Post
I have one horn. Wired it to work in tandem with both the stock horns. What I did was use the power from the stock horn, driver's side, to be the switched power on the relay. The output to the stebel and driver's side horn comes out of the relay. The relay power comes directly from the battery, via 20A fuse. Stebel is independantly grounded and the relay has a good ground as well. My one concern is that I may have gone a little light on the wire to the stebel. I believe I used 20 guage wire. Will double check. I can snap some pics later to better illustrate what I've just explained, a pic is worth a 1000 words eh.
Thanks everyone for your help!!
20 gauge wire is WAY too small for the current draw of the horn. that's getting into the fire hazard range. double check that, cause i'd hate to see someone burn something up from improper wiring.
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
