Originally Posted by el_madmaster
Hey guys. I am changing the oil in the Sequoia right now and took a look at the underbody to see how bad the 5 NY winters were on it - I noticed a bellowing noise that actually sounds pretty good when slowing down recently. I just discovered the cause - turns out the pipe between the first and second muffler (or is the second one - the one where the two exhaust pipes go into - is that a cat?) is completely disconnected, thanks to rust.
Are there any 2 in, 2 outs, that are good and don't result in loss of low end torque, and don't result in replacement of the larger muffler? Someone on here has a Sequoia in their profile pic that has a system I'd be looking for. Also preferably side exit.
There is only 1 muffler on the Sequoia
It goes from the Manifolds down to the cats....
Then the 2 cats feed in 2 ins on 1 muffler
and that muffler has 1 exit.
The pipe goes straight back to a resonator and to the rear bumper.
If you get a 2 in 2 out you will have to have your muffler guy CUSTOM bend your second exit pipe.
Also there are few mufflers with 2 in 2 out that are good for the Sequoia.
You do not want the dreaded DRONE at cruising speeds.
I have the Borla dual exit on my Seq.
2 in 2 out... and its very nice.
I dont know if there are still any out there to buy.
I got mine off of
ebay and I love it.
Check out my photos and you can see the set up and possible some photos to help explain how it looks
