Old 04-25-2008, 02:41 PM
sodamark sodamark is offline
sodamark's Photo Albums
Last Online: 08-11-2008 10:23 PM
sodamark is on a distinguished road.
Default Re: 2001 Liftgate Handle Latch broken
These are great instructions to have. Thanks for posting them. I just replaced the handle on our '01 two nights ago. The only step I did different is
11. Remove the 4 nuts to the window regulator and lift it out of its holes. Push it forward to gain access to the two nuts on the inside of the handle.
Instead, I just removed the three rubber grommets or plugs that are in the upper portion of the door and the top two actually allow you access to the two 10mm nuts holding the handle, and plastic panel in place.
