Originally Posted by Toxarch
There seems to be some confusion as to how to check your software version currently installed in your Z1/Z2. I'll give pictures to show what you should be seeing. This is done on my Z2, but you do the same thing on the Z1. You will just see different numbers displayed.
First you need to get to the service info screen. Follow these steps:
Press the “MENU” key
Select the “Settings” tab
Select “Hardware”
Select “Service Info Screen”
You should now see the following screen:
Touch and hold the top left corner of the screen:
Then you will see this new screen pop up and it will show you the software version on your unit:
that doesn't work on Mine try it allready..
Erik
mine show this screen only will Not pop another screen like u suggested???
