Re: wth...Tundra recall??????
Originally Posted by adamjt
Anyone have any new info on this with the Tundras? My friends friend just had his Tundra bought back at a Toyota dealer whom said it was unsafe to drive. My frame is pretty rusty, especially in one place on both sides wheres rock shoot back from the wheels. I was going to put rust seal or POR-15 on it, but I might try my luck at the dealer after hearing that.
7 year old truck with some rust is normal. I'd recommend you clean the undercariage once in a while. If your dealer says something about a recall being valid for a 7 year old truck frame, I'd be pretty amazed.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
