Old 04-26-2008, 05:22 PM
Lend273 Lend273 is offline
Lend273's Photo Albums
Last Online: Yesterday 07:16 PM
Lend273 is on a distinguished road.
Default Which rotors to cure pulsating?
I have a 2002 Tundra V6, 4wd.
I have been plagued with the pulsating front disc brake problem.
I just had the dealer clean and adjust the rear brakes and emerg brake.
Now I want to install new rotors that are more able to handle the heat without warping.
Which rotors would you suggest? My local auto parts store has a vented rotor that is an upgrade from standard equip. They look like 2 rotors back to back with a space between them to vent out the heat.
Then they have the drilled and slotted rotors that are an upgrade from the vented rotors.
Which ones would you recommend? Do you have an online parts source that you recommend?
Thanks for any info or advice.
Len in NC
