Originally Posted by Canadian_Yoda
What did you use for your fuse holder? I was under the impression that all this hardware came with the horn... guess not
Looks like I get to go dig around at the random parts store
What did you use for a fuse holder? Are you considering changing? (I ask because of your comment above)
this is the fuse holder that i got, except mine has larger wires going to it:
pretty much any automotive fuse holder that is rated for at least 20 amps will work fine. the reason i asked the other guy was because the cylinder glass fuses are usually the ones that the ratshack guys ask what voltage you need, and i prefer to not use them in automotive applications, unless its for low amperage.
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
