Old 04-28-2008, 04:11 PM
LifeTech's Avatar
LifeTech LifeTech is offline
Slummin'
LifeTech's Photo Albums
Last Online: 08-30-2008 10:23 AM
LifeTech is on a distinguished road.
Default Re: Adjusting Headlight Beam
Originally Posted by xclipse129 View Post
I just reinstalled my headlights and now they are blinding people. I noticed that the beam is higher. Is there a way or some sort of screw to turn to adjust the height of the beam pattern. FYI when I was taking my head lights out the bottom piece that sticks out broke off.. I was thinking that is what holds it down more but isnt there a way to adjsut the beam pattern from behind the headligh itself?
The broken bottom tabs of the headlamps may cause aiming problems even with an adequate aiming adjustment. But use the above procedure to get it close.
Driving vibrationa and road bumps may alter the adjustment because of these broken tabs.
Removing the headlamps without removing the bumper cover as required, genrally causes these broken clips. It is hard to break them otherwise.
Good luck.
