JBL Sound system is nice and sound quality is nicely weighted. Since the mids and center channel are on the dash, the soundstage is high....a lot higher than in most cars. I felt that the system had a tad bit more forward bias than I like....a bit more rear fill would be nice. The mid range is also slightly harsh, but will probably tame itself over time (or my ears will get used to them.....depending on which camp you fall under in the speaker break-in debate).
Vern, wasn't sure if you were aware that you can adjust both the forward/rear and left/right bias by using the audio button on the right side of the Nav screen. You can also adjust the low/mid/high ranges to your personal likely through this same set of audio menus.
