Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Aftermarket Products Discussions about aftermarket products and accessories.
This is a discussion thread titled "Which size toolbox for Tundra?", within the Aftermarket Products forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-28-2007, 10:03 AM
steel36's Avatar
Dealer : Atlanta Toyota
2002 Toyota Tundra
steel36's Photo Albums
Last Online: 06-24-2008 10:07 AM
steel36 is on a distinguished road.
Default Which size toolbox for Tundra?
I'm ready to pull the trigger on a Low-Profile single lid box for my '02 Xtra Cab 4x4 but running into a problem. Seems like the best local contenders are UWS and CDI, (the Lowe's version doesn't have an insulated lid). The CDI model is solid (.080 instead of .063 standard) but I don't know anything about them other than that they're the new brand being carried by my local truck accessory shop. I know the reputation of the UWS and would go with it but the 69" model will hang over just a bit (sticking out straight above the rounded rail caps) and I don't like that idea, while the 66" model is only 54" wide in the actual box, leaving about a 3 1/2' gap on each side in the bed. What is everyone else doing?
I'm not really a praying man, but if you're up there, please save me Superman. -Homer Simpson
Old 09-21-2007, 05:16 PM
Preferred Dealer
Dealer : Toyota Of Stafford
Cliffy1's Photo Albums
Last Online: 10-10-2008 05:46 PM
Cliffy1 is on a distinguished road.
Default Re: Which size toolbox for Tundra?
I forget which brand I had on my 2003, but I'm pretty sure it was 70". It overhung a bit, but not enough to worry about. I wouldn't go any bigger.
Now a sales manager at Stafford Toyota in Stafford VA. Call 540-720-4700 and ask for Steve Clifford... they will not know who "Cliffy" is.
Old 11-19-2007, 08:39 AM
Dealer : Webb Toyota
2005 Toyota Tundra
PEPITO's Photo Albums
Last Online: 12-06-2007 07:52 AM
PEPITO is on a distinguished road.
Talking Re: Which size toolbox for Tundra?
I have a 05 dc and bought a uws box. It fits down under the bed rails. Doesn't sit on top. I could put a tonneau on with no issues. at the moment I don't remember the width but it fits perfect, I mean inside the plastic bedrail covers, barely rubs both sides. Whatever the width of the 05 tundy bed is. Now for the wheel well cutout on the rear facing side of the box is a c-hair not enough soooooo I fixed that. Under the box, inbetween the box and the bed, I cut two lengths of 1" square tubing to the appropriate length. Running with the length of the truck pretty much in line with frame rails. Four or six bolts thru box, 1" square tubing and the bed and you have it. Even raising the box with the tubing still didn't raise it above the bedrails. I did this so there would be room for crap to accumulate in, under and around the box so it would be a bee-ach to clean. It really cleans out well. Well... with a hose and park facing uphill!! I did have to fasten it to the front of the bed,(behind the cab) I just used selftappers. Probably gunna haf to keep checking these ones tho.
And since the way the lid opens, it would hit the front bed rail rubbing paint and just annoying. Soooooo, I drilled some holes and with an old bike chain and some bolts made some..."toolbox-lid-keepers-from-hitting-the-front-of-the-bed-thingies". You know, the things that keep the lid from opening up too far? I can't for the life of me think of what to call them...I will get some pics, its totally TRICK!
Anywho. I love the UWS box but think it could be a little thicker alum. Pretty thin but a great fit!!!
I would rate it a 7 out of ten. I don't know if they come with trays but mine did not.
Pepito~
Old 11-19-2007, 08:40 AM
2005 Toyota Tundra
I have a 05 dc and bought a uws box. It fits down under the bed rails. Doesn't sit on top. I could put a tonneau on with no issues. at the moment I don't remember the width but it fits perfect, I mean inside the plastic bedrail covers, barely rubs both sides. Whatever the width of the 05 tundy bed is. Now for the wheel well cutout on the rear facing side of the box is a c-hair not enough soooooo I fixed that. Under the box, inbetween the box and the bed, I cut two lengths of 1" square tubing to the appropriate length. Running with the length of the truck pretty much in line with frame rails. Four or six bolts thru box, 1" square tubing and the bed and you have it. I did this so there would be room for crap to accumulate in, under and around the box so it would be a bee-ach to clean. It really cleans out well. Well... with a hose and park facing uphill!! I did have to fasten it to the front of the bed,(behind the cab) I just used selftappers. Probably gunna haf to keep checking these ones tho.
Pepito~
Old 11-19-2007, 05:01 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
123Gone's Photo Albums
Last Online: 10-10-2008 04:23 PM
123Gone is on a distinguished road.
UWS is pretty good bang for your buck and that's what we sell the most. But, if you want to step up, choose either Weatherguard or RKI (Rawson-Koenig). That's what ALL my commercial accounts buy. They are more expensive, but worth it.
Old 11-20-2007, 10:36 AM
derone's Avatar
Dealer : Leith Toyota
2001 Toyota Tundra,
- Other -
derone's Photo Albums
Last Online: 10-10-2008 01:05 PM
derone is on a distinguished road.
See my pics for the UWS 66" low-profile in black. The gaps on the bed sides of the box allow use of the front tie-down hooks in the bed.
Doug
'01 tundra TRD SR5 4x4 access cab, rear Helwig sway bar, front poly end-links, temp/compass mirror, '05 tail lights, JL audio stealthbox and amp, 6x9 Sony rear spkrs, TO-25 door tweeters, new '03 TRD coilovers w/daytech 3/4" poly spacer, rear HD-Bilsteins, all weather mats, rear seat mod, Draw-Tite bugshield. Soon to install: TRD lim-slip
My photos
Old 11-23-2007, 10:50 PM
Dealer : Toyota Scion of El Cajon
Drayday55's Photo Albums
Last Online: 09-28-2008 11:21 PM
Drayday55 is on a distinguished road.
i know they are expensive but weatherguard all the way!
i had my truck broken into to many times and my tools stolen. now with my weatherguard the theaves just walk buy. the aluminum is so thick compared to husky, betterbuilt etc, you can stand on it with no problems. and it has clear powder coat
initially it is more but worth it! p.s. low profile for 07 tundras. i cant see out my back window very well with my regular size.
Old 11-25-2007, 09:16 PM
Dealer : Muller Toyota
2004 Toyota Tundra
04bluetrd's Photo Albums
Last Online: 07-14-2008 10:17 PM
04bluetrd is on a distinguished road.
Unique Truck Accessories makes a box to fit the 1st-Gen Tundra. I have the low profile myself, and it looks and fits great. I have to try and get some pics in my gallery of it, but if you do a search of the company, there's another member who has pics of one.
Similar Threads for: Which size toolbox for Tundra?
What size toolbox? blanksb Tundra 13 01-25-2008 08:57 PM
Best looking tire size on Tundra... look at the pic here Agent WD-40 Tires and Wheels 29 02-24-2006 02:24 PM
Cargo Covers & Toolbox space??? c350 Sr5 Interior & Exterior 1 11-17-2003 12:05 PM
Oddball Tire Size? Rick Tires and Wheels 1 10-01-2003 08:32 AM
Stupid Question on Tire Size and Speedo Ripper Tires and Wheels 7 09-16-2003 01:19 AM
