Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 09-11-2007, 03:36 AM
N2K's Avatar
N2K N2K is offline
Dealer : Findlay Toyota Scion
2002 Toyota Tundra
Last Online: 01-07-2008 10:39 AM
N2K is on a distinguished road.
N2K's Photo Albums
Default Bushings?
After taking my truck through some water for the first time, the upper and lower control arm bushings plus the sway bar, I believe, are all squeaky now. I tried spraying them with lubricant and it didn't work. I want a suspension upgrade, can't afford it yet, saving up for the Camburg Long Travel Off-Road System.
My question is, what do you guys recommend for new bushings?
Old 09-16-2007, 11:18 PM
2002toytundra's Avatar
Dealer : Jim Norton Toyota
2002 Toyota Tundra Black SR5 2WD Access
Last Online: 09-22-2009 02:15 PM
2002toytundra is on a distinguished road.
2002toytundra's Photo Albums
Default Re: Bushings?
Don't know on the bushings, but I would be careful getting that much water in the engine area. Water sucked through the air intake is a quick route to a new engine.
Old 09-18-2007, 05:13 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Don't worry too much, I've had my engine compartment much worse. Clean with the engine running, use Simple Green at 50% dilution, don't spray water directly at any of the electronics or fragile components (I usually spray at the underside of the hood, or spray from a distance so it's more like misting) and then drive it for 10-15 minutes or so to get any water out from the spark plug wells and other parts.
The squeaking is from the same gunk in your engine bay...it's all over the bushings now too. Use any kind of grease you want...regular black chassis grease works fine, all the way to Green Grease (buy online). It's not too hard to add grease ports to the swaybar straps, and I've added them to my 1st-gen T/C arms. Not sure if it's worth the trouble on the stock arms if you're going to replace them, all the Total Chaos arms come with grease fittings now.
-Sean
GFX by FreedomEagle50
Manual Hubs
Loose rack and pinion bushings. ktdaddy 1Gen-Sequoia 18 11-21-2009 11:46 PM
Opinions on Energy Suspension Front Sway Bar Bushings shall36 Suspension & Axle 1 12-10-2006 02:15 PM
Energy suspension FRONT swaybar bushings instead of Daystar? keninsb Suspension & Axle 24 08-10-2006 10:46 PM
ORW Steering Rack Bushings Install Question Picasso Suspension & Axle 2 09-14-2004 06:19 PM
Daystar Sway Bar Bushings, What kind of Noise? keninsb Suspension & Axle 8 01-05-2004 10:48 PM
