Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 10-13-2007, 12:14 PM
tacomatrdsport2591's Avatar
Dealer : Fairfield Toyota
- Other - '87 Corolla FX16 GTS
Last Online: 06-05-2008 09:30 AM
tacomatrdsport2591 is on a distinguished road.
tacomatrdsport2591's Photo Albums
Default air/fuel ratio gauge...
I know there are alot of variables from engine to engine, but can anyone give me a general idea of how difficult it would be to install an air/fuel ratio gauge in my 87 corolla with the 4age engine? =] thanks!
"Close your mouth before you chew."--Marie Barone....."Close your mouth before you talk!"--Frank Barone
Old 10-14-2007, 11:23 AM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Default Re: air/fuel ratio gauge...
A narrowband or wideband A/F gauge?
A narrowband uses a normal O2 sensor,you can tap the signal wire in your pre-existing sensor,there also may be an output you can tap into from the diagnostic port under the hood.
A wideband gauge requires its own sensor and costs more. Most widebands have additional outputs (like a narrowband 0-1volt signal)s o you can replace your existing O2 with the wideband and use the gauge output for your ECU's O2 sensor signal input.
Old 10-14-2007, 02:03 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 07:39 PM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
I would go straight for the wideband, especially if performance tuning is the purpose. Normal O2 sensors are almost useless at heavy engine loads. They only work accurately when the air fuel ratio is near stoichiometric (14.7 to 1) which is not what the mixture should be at or near full throttle.
Old 10-14-2007, 07:43 PM
Thanks so much for the input guys! Now that I have an idea of what to do, this seems like a fairly quick, no-problem add on. The O2 sensor in this car is exceptionally easy to get to...and my main goal in getting a gauge is actually to help myself with shifting efficiency and to see how my car is breathing. Narrow band sounds acceptable, but I am thinking I would probably lean towards wide-band. Do you guys have an suggestions or tips on where to go to find a good deal? Thanks once again, I appreciate it.
Old 10-20-2007, 11:36 PM
mc71454's Avatar
Dealer : Steet Toyota of Johnstown
2007 Toyota Tundra DC 5.7 TRD 4x4
Last Online: 11-04-2009 12:51 PM
Images: 9
mc71454 is on a distinguished road.
mc71454's Photo Albums
Don't just lean toward the wideband only get a wideband.
The narrow band is useless for tuning. I use the F.A.S.T. system with dual widebands in my race cars. For a goof I tried a narrow band to see if I could any useful data..sold it on Fleabay a week later.
Tom B.
2007 - DC TRD 4x4, Slate, 5.7 SR5, Toy-Tech 3", 285/75/18 Toyo's Open Country AT , Bedrug, Truxedo Tonneau, N-Fab Nerfs, Eclipse NAV, MB Quart, RFosgate, etc., Snow-Way, TRD Sway Bar
1971 Chevy Monte Carlo Street/Strip - 10.31 @ 130
1970 Chevelle 454 LS6 Power
1987 Olds 442 - Stock
Racing Web Page
