Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 01-20-2008, 06:01 PM
TundraZone2001's Avatar
Dealer : Star Toyota
2004 Toyota Tundra
Last Online: 10-03-2008 01:48 PM
TundraZone2001 is on a distinguished road.
Send a message via AIM to TundraZone2001 TundraZone2001's Photo Albums
Wink Off road light wiring help!!!
I am in need of help. I got the damn things mounted on my aries brand bull bar on my 04 access cab tundra but they dont send you instructions on how to install it. I can connect the wires but how and where do you put the relay and switch??? they charge 100 bucks to do it but i know i can do it if i had some help from someone. if anyone has experience doing this please help me out with pictures or something. i got all the tools needed i got the KC slimlight series if that is needed to reference. HELP PLEASE!!!!!!
-Clay
Old 01-21-2008, 06:56 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Default Re: Off road light wiring help!!!
From KC's website
http://www.kchilites.com/store/faq/i...layDiagram.pdf
You could bypass the switch and connect the green (load) wire to the positive wire of your highbeams.
Old 01-24-2008, 02:47 PM
2004 Toyota Tundra
YEAH I DONT WANT TO DO THAT! I WANT A SEPARATE SWITCH INSIDE THE CABIN. can anyone help me out???
Old 01-24-2008, 03:01 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Here's how I wired my Hella 500's. If you do not have an aftermarket fuseblock,think of the + and - as continuous with a fuse on the + wire between the battery and relay.
Mike
http://dyogim.blogspot.com
Old 01-24-2008, 06:55 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
There's no need to TYPE IN CAPS,it's like YELLING TO SOMEONE IN PERSON.
Are you having a problem running the wires into the interior or a problem wiring the lights? If it's wiring,the diagram from KC's website is pretty self-explanatory. Did KC furnish a wiring harness and relay?
Old 01-24-2008, 07:25 PM
2004 Toyota Tundra
Wink Re: Off road light wiring help!!!
yeah sorry about the caps!!! Umm KC gives you a wiring diagram but its not vehicle specific!!! I need to know exactly what to do for the truck. I know i can do it just tell me how to run the wires and mount the switch and all that jazz. the instructions are very vague for someone that has never done this stuff in their life.
Old 01-24-2008, 09:30 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
I'm going by the colors in the KC website diagram I posted. I highly suggest using a multimeter or at least a test light.
Run the green wire through a grommet on the firewall,more details here: http://www.tundrasolutions.com/forum...l-for-dummies/
If you want to be able to switch on the lights basically any time,connect white to the cigarette lighter's positive wire. Switch on only when the parking or headlights are on,connect white to the lighter's illumination positive wire instead. This is where a multimeter or testlight is needed.
Brown is a ground,self-explanatory.
Most people mount switches in the area where the stock foglight switch is located. Search around,you should find posts and pics. Here's a recent thread Switching to Missiles
The relay mounts in the engine bay. There are several threaded holes all over,most of them use a 6mm x 1.0 bolt, Go to a car parts store or home improvement store and get some of those bolts to mount the relay and for grounds. You may need to open up the relay's mounting tab hole.
85,86,87,and 30 are the terminals of the relay. Turn it upside down and you should see the numbers. Connect the wires to the terminals according to the KC diagram. Black is a ground,so is the other wire connected to each light. Yellow connects to the battery's positive terminal. Do not install the fuse until everything is wired properly.
Old 01-24-2008, 10:05 PM
2004 Toyota Tundra
if anyone has pictures and step by step instructions that would really help out alot!!!
Old 02-02-2008, 03:36 PM
2004 Toyota Tundra
Anybody out there!!!! I need pictures of how to run the wires and hook them up.
Old 02-02-2008, 07:41 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
Originally Posted by Toxarch View Post
If you still can't figure out how to wire up the lights after the previous posts, then you should either ask for help from a friend and learn as they help or just pay the $100.
I was about to say the same thing...
Old 02-05-2008, 09:45 PM
2004 Toyota Tundra
yeah I figured as much!!!! Just thought someone could help me out thats all!!!
Old 02-05-2008, 11:17 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
You have all the reference to wire the the lights. It's your decision where and how you run (locate) the wires.
Mike
Old 02-05-2008, 11:30 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
You can take a look at my thread on Yotatech.com (link in my signature). I have some pictures of how I wired my driving lights up, nothing too detailed though. Warning, that thread has a LOT of pictures If you have any doubt, I'd get someone to install them for you, I wouldn't want you to burn down your truck or anything
Old 02-07-2008, 10:13 AM
2004 Toyota Tundra
Had them install them yesterday!!! the only dislike i have is the how they put the switch in the cabin. I thought those two blank black things next to the dash dimmer come out. the switch sticks out and is not back in there flush with the dash. if you think its something i can fix or not let me know otherwise i am taking it back to them and see what can be done. I could have done wired the lights in the engine bay but getting them in the cabin was kinda scary for me. I just didnt want to mess anything else up.
-Clay
Old 02-07-2008, 11:44 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
-Clay
The two blanks do come out but, the inside not the outside. You'll have to remove the lower trim in order to access. Here's how my switches look
Mike
