Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 04-11-2008, 12:10 PM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 09:06 PM
Images: 578
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Default Air Tanks, Part Deux
Anyone know who sells a stainless steel air tank? I like the Viair tanks, but they are powder coated. I want stainless steel because I will be mounting it underneath the truck.
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 04-12-2008, 12:47 AM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Default Re: Air Tanks, Part Deux
You'll be adding a lot of weight for nothing, not to mention stainless steel especially 304 stainless which is what an airtank will likely be, will be EXPENSIVE!!!!
I had my powdercoated tanks on for a LONG time and I never had rust problems. I never saw the VIAIR powdercoating come off either and mine were each right behind each tire and running 35" mud tires, plenty of rocks were thrown at them.
If you do find them, post up, but I haven't seen them.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Old 04-12-2008, 07:06 AM
Salty_Dog's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 578
I've found some 5-gal SS tanks on some of these sites that cater to the Slammed and Bagged crowd, but that may be too big for mounting under the truck.
How big are your tanks?
Salty Dog
Old 04-12-2008, 11:29 PM
Imdone's Avatar
Images: 23
2.5gal. Putting a 5 gal under the truck will be pretty tricky even if it is more like a hotdog rather than a propane bottle.
I had 2 mounted under the truck so I had 5 gallons of air total. When you connect them it runs pretty seamless.
Old 04-14-2008, 12:24 PM
Salty_Dog's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 578
Do your Viair tanks have a port on the bottom where you could insert a drain valve?
Salty Dog
Old 04-14-2008, 06:00 PM
Imdone's Avatar
Images: 23
There are 6 bungs total on each tank. 1 on top 1 on bottom and 2 on each end, this way no matter how you mount them you can always have a drain valve.
They are quality tanks, I wouldn't worry too much about them. I thought for sure I was going to dent the piss out of them, but they held up really well.
Old 04-25-2008, 03:22 PM
jim65wagon's Avatar
Dealer : Palmiero Toyota
2003 Toyota Tundra SR5 4x4
Last Online: Yesterday 08:24 PM
Images: 3
jim65wagon is on a distinguished road.
Send a message via AIM to jim65wagon jim65wagon's Photo Albums
CB, got mine used and the powdercoat still looks good, the 2.5 gallon tank fits in the C-channel under the passenger door.
And if you find the foglight switch from a 2000, you can run you compressor from the dash.
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake with AEM dryflow; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380COBA; Donahoe coilovers; Deaver 3leaf AAL; homemade bed rack; 21 gallon water tank, front Hidden Hitch w/Superwinch...
The 140,000 Mile Tundra Thread
Old 05-02-2008, 08:30 PM
whateverz's Avatar
2000 Toyota Tundra,
Last Online: 10-27-2009 10:11 PM
whateverz is on a distinguished road.
Send a message via Yahoo to whateverz whateverz's Photo Albums
Ya, for the price of stainless you can run through a few Viars's. My 1Gal has 8+ trips down Baja in the last 4-5 years. You can see all the pics of the tank and controls here...
Comp/tank - Tundra Solutions Photo Gallery
I just noticed a crack on the lower mount, a few tacks fixed that. No drain, but no problem yet. With the locker either. I put a quick connect on the frame rail too, and that cheap cover has never fallen off. (I'm going to be going a lot of knocking on wood here in a min!!!)
Jim where is you compressor? Good job on shoving the 2.5 in there, I wish I had that. Airing up with that little pump and tanks SUCKS in the sun!!
08' Tundra DC, SB, 5.7, 4x4, Sky Silver
3" Toytec lift in front, Diff drop, Ride Rite airbags. 305/65/18 BFG A/T's on 18x9 Ultra Magnus, Prodigy in tow/haul button cubby.
Girlfriend got the ol' girl.... (keep her in the fam)
2000 Tundra, AC 4x4 V8, Donahoe LT coils, TC upper arms, TC diff drop spacers, TC steering bushings, sway bar bushings, custom Deaver 11 leaf spring pack, Ride Rite Airbags, Fox shocks on rear, Viar compressor & 1 Gal. tank on frame rail with quick connect, ARB Air Locker, True Flow drop in filter, [/B]Jetchip (bought another ECU, so stock now), [/COLOR][/B]Downey ceramic headers, Custom Y pipe, 40 series Flowmaster, Centric Drilled and Slotted Rotors & Carbon Kevlar Pads, AR 16x8 Teflon Mojave's, 285/75/16 BFG A/T's, Snugtop Extra Vision top, Yakima racks and Space Booster, Brake Controller, PIAA Super Extreme bulbs, Clear Corners, Light bar w/ 2 Hella Rallye 4000 Euro Beam, GMC sierra fog lights in stock location, Optima battery, Sony mp3, powered Alpine speakers, 2-10's in a MTX Thunderform
Old 05-04-2008, 07:00 AM
jim65wagon's Avatar
Images: 3
It's under the hood between the airbox and the ABS. Of course the stock airbox is no more....I have an AEM dryflow filter, mounted on a blingy chrome tube from an old SSAutochrome setup. AEM resides in a custom airbox (much smaller footprint than the OEM box).
Viair 380C with a 150psi pressure switch/relay.
If you look below the compressor you can see the mounting holes for the original airbox.
