Hello everyone - great site and glad to be a member!
OK - have the 07 Tundra and just picked up an 8 foot Okanagan Camper. Already had Firestone airbags on the bench ready for install - any suggestions for best method to cut off the jounce bumpers - recipro tends to get very smoky - one suggestion was to add a bit of lube to the recipro blade - a knife tends to bind. I know someone out there has done this before.
i used a utility knife with a fresh razor and had them both cut in 15 minutes. it helped a lot to push the stop away from where i was cutting, 'opening' the cut.
someone also loosened the u-bolts enough to remove the stop entirely.
__________________ 2008 Tundra Crew Max Limited 4x4 5.7L Sunroof 20" Wheels Skid Plate Enhancement XM Anodized Aluminum 'T' Shifter Stebel Nautilus 110dB Compact Air Horn Air Lift LoadLifter 5000 Air Springs
Thanks - I'll have a look at both methods - any ideas what torque spec would be if I follow the u-bolt method? I also now see there is a section on suspension - I guess scrolling down has its advantages...oops
Started that way but ended up looking and smelling like the Exxon Valdez on fire - went to plan B - way cleaner. Murphys Law was dictating that I would have probably reciproed through my brake cables and sensor lines anyways so its good I stopped.
Thanks Toxarch for the spec - I also posted in suspension - just ignore that - that torques is quite a bit lower than previous models eh?
OK, installed the airbags and tightened the u-bolts to 74 ft/lbs - seemed like it was about right as far as pull was concerned. For the heck of it I called my dealer and the service techasked a mechanic who came back with 52 ft/lbs. Great - Is the tech maybe talking about the driveshaft u-bolts (thats probably too high, eh?)
Does anyone have an 07 manual or is that where you got your info, Toxarch?
Thanks again.
Neil
Thanks again.
Neil
which u-bolts are you talking about? the airbag u-bolt spec is in the instructions. if you removed the u-bolts that hold the axle to the leaf springs to take off the bump stops, i'd go with the spec a toyota mechanic cited for those.
Thanks for pointing that out - never looked at it that way. This would be the u-bolts that hold the axle to spring pack. I dunno - 52 ft/lbs seems a bit light.
Thanks Tox -I did have confidence in you - thats what I had torqued to already - did some other poking around - 52 ft/lbs is what the drveshaft to yoke bolts are - communication is the key. Thanks everyone for your help. Now to begin building the camper tie downs....
