Who has installed the Weathertech In-Channel Side Window Deflectors?
I have a set of (4) Weathertech In-Channel Side Window Deflectors that I want to install on my 08 Tundra Double Cab.
Can anyone provide some tips, pointers or cautions? What is the best installation technique?
In the past I have only dealt with the adhesive attached outside mount type deflectors. I also see that the rear deflectors of these In-Channels for the Double Cab also has some sort of adhesive strips to aid in attachment.
Re: Who has installed the Weathertech In-Channel Side Window Deflectors?
They are very easy to install.Follow the instructions and you'll be fine.There's no trick just be careful not to bend them to much just enough to install(you have to bend them a little to get them in the channels).They look better than stick ons but I don't like the outside wind noise I'm getting now.
They just press in the channel and the rears are double sided tape that press on.I've had the press on type on 3 other cars.Over time the tape may loosen so make sure you clean the area well before you stick them on.Everything installs within 30 mins.I'm somewhat happy just the wind noise I not happy with.Would I buy them again? I'm 90% sure I will.
i did it in 15 minutes
its a snap
wind noise is frustrating though.
looks MUCH better than the wal mart looking stick on type.
2005 Silver Sky Texas Edition DC SR5 w/moonroof, 20" rims, Magnaflow Catback, Doug Thorley Headers, Tuned Unichip, Downey FSB Endlinks w/ES Bushings, Downey HD Off Road Skid Plate, Hellwig RSB, Total Chaos Steering Rack Bushings, TRD Springs, Bilstein 5100 x 4, ASP Underdrive Pulley, Bazooka VSE, Panasonic CQ-C8803U w/bluetooth/Sirius, Polk 6750, Polk 675, 6000K H/L HID, 6000K HID Fog Lights, Sanded Out Gauge Cluster, LED Cool White Bulbs up top and blue down low, All LED Exterior Bulbs, TRD Mesh Grille Insert, Scangauge II.
2005 Lunar Mist Camry LE, Custom Leather, TRD Strut Bar, TRD Rear Sway Bar, SS Ultra Beams, K&N AF,
JVC KW-AVX720 w/Sirius, Polk 690
They are simple to install but if you are really worried about it...the dealer will likely do it for you at no charge when you have your oil change done if you ask pretty please
2007 Tundra DC 4.7 SR5 TRD 4X4
Garmin Nuvi 1300T
Stubby antenna
Clear Bra,
ARB Bumper,
Line-X,
325/60/18 Nitto Terra Grapplers,
18" KMC XD Hoss Black,
ARE CX Series Topper,
KC Rally 800 long range lights,
Tinted windows,
Wet Okoles Frt & Rear,
Weather Tech rain deflectors,
Weather Tech floor liners frt/rear,
Ready Lift 2.4"
Bel Vector 995 Radar Detector,
Wilson cellular booster,
Cobra 75 WX ST Compact/Remote CB,
Sirius Satellite Radio,
S&W .38 Spl Laser grip (hot pink),
TRD sway bar (black widow style),
Debadged except TRD sticker,
Roxy Sticker
TS Tank Top
____________________________
Wish list:
Horn Blaster train horn, ARB rear bumper (if they ever make one) or line-x rear bumper, Color matched fender flares, Underseat storage of some sort, Winch (if i can ever afford one), GPS system! Sun roof! Going broke thinking about it.
__________________________________________
I need a new word of the month people!
Do it in the sun in the heat of the day, take your time and don't force it! Mine cracked the leading edge (on the flange part that sits in the channel) the first time I rolled the window up, but no problems since. They are much better and better looking than the adhesive type.
We pay a premium for shipping but IMHO they are worth every $. I have had the ones on a '94 Toy Xtracab Pup get cracked and pieces chipped and have repaired with SUPER GLUE with no issues. Follow the enclosed directions and ensure the in-channel surface is clean and dry! I have sets on the '94 Pup (14 years installed, not garaged), '04 NISSAN Altima 3.5SE, and most recently '08 Corolla CE.
I had them on my malibu 4dr and I loved them. The only problem with mine was I did not clean the channel good enough and the right rear would fall of the track when I rolled the window down. I ended up taking the rears off and leaving the fronts. They are super easy to install and once they are in they stay unless like me the channel was dirty and the thin double sided tape got dirty. The instructions are very clear adn easy to follow. I had the stick on ones before and the inchannel is far more superior and they look a lot better.
'07 SR5 DC 5.7 silver sky metalic
5% tint rear windows, 2 Flowmaster 40 series w/ dual tips out the back, Carriage Works polished grill overlay w/emblem, 3-piece bumper inserts (not CW), Airaid, Ground Force rear shocks, DJM 3" arms, belltech flip kit, 22" BOSS 329 w/ 305/45/22 General grabber UHP, G2 bakflip.
