Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 12-10-2008, 10:13 PM
Dealer : Draper Toyota
Last Online: 08-09-2009 05:59 PM
Bulletproof77 is on a distinguished road.
Bulletproof77's Photo Albums
Default Line-X Question
I'm having my truck(Crewmax 08') bed Line-X'd and I thought I read somewhere in here about certain things you should request them to do before you give them the green light ti Line-X the bed.
I wanna say there was a thread that mentioned removing bed bolts/brackets and possibly the tailgate done seperately?
Does anyone have any info on this? What should be done before the spray is actually applied to prevent any future headaches?
Thanks.
Old 12-11-2008, 05:08 PM
george60's Avatar
Dealer : Geweke Toyota Scion
2003 Toyota Tundra
Last Online: Yesterday 10:02 PM
george60 will become famous soon enough.
george60's Photo Albums
Default Re: Line-X Question
Line-X took my tailgate off and masked and did seperatly.(sp) I let them go right over the bed bolts because I wanted the protection and I don't think I'm going to be pulling the bed off anytime soon.
George60
LACK OF PLANNING ON YOUR PART ----------------
DOES NOT CONSTITUTE AN EMERGENCY ON MY PART !!
Old 12-21-2008, 11:04 AM
08SalsaMax's Avatar
Last Online: Today 08:02 AM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
Thanks.
They guys that did mine took out the bed bolts, bed rails and the panel on the tailgate. They did the panel separately so I could access the area inside the tailgate. I had them spray over the strap down points as they had had prior experience with the paint on the bolts chipping when they were removed. I think it looks fine being overspreayed. Hope it helps.
Old 12-22-2008, 05:13 PM
c7fx's Avatar
Dealer : Premier Toyota Scion
2008 Toyota Tundra TRD limited 4x4 dc
Last Online: 09-13-2009 03:27 PM
c7fx is on a distinguished road.
c7fx's Photo Albums
Just had mine done with line-X Xtra. The removed the bed bolts and the panel to the tailgate latch. The tie downs in the corners they did not remove but removed the adjustable tie down and the plastic bed rails.
Don't panic if they don't take the bed bolts out since after a few winters they become more of a bitch than chipping the line-X off. Hope that helps. I actually was told they would cover my bed bolts but to my surprise the didn't. Not a big deal to me so I let it slide.
Old 03-25-2009, 05:37 PM
Dealer : Toyota of Colchester
Last Online: Yesterday 05:14 PM
Echo6 Sierra is on a distinguished road.
Echo6 Sierra's Photo Albums
The shop that did mine removed the bed bolts, tailgate screws and the four tie hooks in the corners of the bed. I meant to ask them to do this but forgot but they did it anyway.
My buddy had his done at the same place and they went over everything. Not sure if they took extra time with mine because it was new or if they changed their techniques. Overall I'm very happy with the job, this stuff is hard as nails.
Old 03-30-2009, 01:28 PM
Dealer : Heyward Allen Toyota Scion
2007 Toyota FJ Cruiser
Last Online: 07-31-2009 02:11 PM
joeberg is on a distinguished road.
joeberg's Photo Albums
I just got a quote and they said they do not do over the bed rails on the tundra. Is this normal? Is it a big deal? I know I have read that some do get the bed rails sprayed. They quoted $425 under the rail and another $25 to remove/put back my tiedown rails.
Joe
Old 03-31-2009, 08:40 PM
The shop I went to went right up to the factory plastic side rails. I have seen other truck that went over the top and it didnt look as good IMO. Here is a pic of mine.
Old 04-01-2009, 10:36 AM
andoneward's Avatar
Dealer : Valdosta Toyota
Last Online: 10-30-2009 02:12 PM
Images: 3
andoneward is on a distinguished road.
andoneward's Photo Albums
Echo6...I like that you left your tie downs white instead of being line-x'd. I was debating about leaving mine blue, but after seeing your picture I am definitely going to keep them blue. Looks sharp.
~Matt
2008 Toyota Tundra Crewmax Bluestreak
CBTMA Member...woot woot!
Old 04-01-2009, 01:39 PM
Thanks. It looks really good. I am getting mine done tomorrow.
Joe
Old 04-01-2009, 04:08 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: 11-20-2009 10:34 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
I highly recommend you consider spending a little more and get LINE-X Xtra unless you plan on getting a tonneau cover, then you really don't need it.
The plastic rail caps on Tundras and Fords should not have a bedliner product applied to them at all. What might have seen is perhaps a Chevy, for example, that does not have plastic rail caps and the bedliner was applied "over the rails".
Old 04-01-2009, 05:11 PM
Thanks for the kind word guys but like I said, I forgot to tell the shop to remove the bolts. They removed the bolts from the bed, the screws from the tailgate and removed the tow hooks on their own. If you want that done on your ride, let them know when you drop off the truck!
