Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 05-26-2009, 03:24 AM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 01:38 AM
RichR is on a distinguished road.
RichR's Photo Albums
Default Waterproof lock
I need to cut two locks off our Tundras.
I use them with a cable so the spare canot be stolen.
Corrosion usually gets the every 2 1/2 years.
These are both Master locks with the plastic case.
Thanks for any help.
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 05-26-2009, 10:13 AM
rambrush's Avatar
Ever the explorer
Dealer : Findlay Toyota Scion
2006 Toyota Tundra,
2003 Toyota Avalon
Last Online: Today 08:10 AM
Images: 83
rambrush will become famous soon enough. rambrush will become famous soon enough.
Send a message via AIM to rambrush rambrush's Photo Albums
Default Re: Waterproof lock
To cut these off you can utilize a sawzall with a good quality metal blade or a Die grinder.
It might be easier to cut the cable with cutters?
There is a method called shimming to open pad locks but I will not go into that here on this open forum. You might be able to find something with Google though.
ARB Sahara,Front Springs www.coilsprings.com Firestone Ride-rites 2245, Hell roaring technology dual battery setup, Wrangler dual battery tray, (2) Odyssey PC1200T batteries, Tru-speed recalibrator, Toyo open country MT 265x75x16's, USA Spec PA-15,AmSteel 7/16 x 90' synthetic winch line, 100' AmSteel 7/16 extension rope, Fumoto quick drain #F103N.
Future Ideas
Winch Warn 16.5ti coming soon..
Sliders Stubbs
Lockers ARB
Viar 460c w twin 2.5 gal tanks
255 x 85 x 16's
4:56 gears
Skid row skid plate package
Old 05-26-2009, 08:42 PM
george60's Avatar
Dealer : Geweke Toyota Scion
2003 Toyota Tundra
Last Online: Today 02:42 AM
george60 will become famous soon enough.
george60's Photo Albums
A Dremel tool we work too. They come with a variety of blades. Included are diamond blades.
LACK OF PLANNING ON YOUR PART ----------------
DOES NOT CONSTITUTE AN EMERGENCY ON MY PART !!
Old 05-26-2009, 10:12 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
How about some type of hitch lock?
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 05-26-2009, 11:38 PM
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
Sorry,
My zombie post was to ask about finding good water proof locks from your experiences.Especially northern(SNOW/SALT)members.
I cut them off today with bolt cutters.
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 07-17-2009, 09:39 PM
2006 Toyota Tundra Silver Sky MetalicDC
Last Online: 07-30-2009 04:32 PM
Chawfon is on a distinguished road.
Chawfon's Photo Albums
Angle Grinder with metal abrasive blade and 2 mins on one side of the shackle or cutting torch and 4 seconds... not that i have done this multiple times.
Old 07-18-2009, 07:53 PM
kerryman71's Avatar
Dealer : Harr Toyota
2002 Toyota Tundra SR5 AC V8 4X4 TRD
Last Online: Today 06:03 PM
Images: 27
kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything. kerryman71 has done just about everything.
kerryman71's Photo Albums My eBay
I recently had the same problem. I decided to lower the spare
and put some air in it and see if anything needed to be lubed.
I couldn't get the lock unlocked so had to use bolt cutters to get
it off. I replaced it with a Masterlock weather proof lock with
the plastic enclosure. Before doing so I put some antiseize around
any areas that may get rusty. I then taped it up with some
electrical tape to be on the safe side and tucked the lock up around
the cable so that it isn't just hanging in the breeze. I think
the best thing to do is unlock it each spring and take a wire brush
to any areas that look like they have rust forming. Also spraying
some penetrating lube would be a good idea.
John
The fools, the fools the fools! They have left us
our Fenian dead, and while Ireland holds these
graves, Ireland unfree shall never be at peace!
Padraig Mac Piarais (Patrick Pearse)
Old 07-19-2009, 11:17 AM
firemanmike's Avatar
Dealer : Toyota of Waldorf
Last Online: Today 04:09 PM
Images: 4
firemanmike is on a distinguished road.
firemanmike's Photo Albums
I have used a regular lock with often application of WD 40. works for me.
Old 07-20-2009, 03:26 AM
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
Mike,
I also used Master plastic covered locks.
But this time I took a big ziplock baggie and zip tied it around the lock.
Then I tucked it up in the frame/rear bumper.
I find out if this will help.
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
