Re: Final Verdict on 05-06 Clear Corners
I have a access cab and i didn’t have to shave them or cut them at all. I bent the tab up top so the pop out on top fits. I also Drilled a small hole on the bottom of the clear( near where u put the Bulb in, not visible unless ur looking for it under the hood) and used two zip ties to tighten it super tight. It doesn’t move on bit and it is really snug. I will take pics and put them up in my gallery so you can see. For the double cab im sure it’s a little different but they all can be customized a bit to fit perfect, plus they look way better then the gay orange reflector.
