edmunds.com has athread about fuel and oil additives. This of course came up many times. One of the guys did his "scientific" testing and pretty much came up with that it didn't help any plus the added hassle, potential damage to fuel pumps and other $$ parts of the system made it a waste.
If anything for most of those trying it here is probably the scenario. Acetone is very strong solvent, as a result the fuel injectors and associated are getting cleaned resulting in better flow/vaporization etc.
I can say the same for BG44K and probably Seafoam. All the cars I put it in had more power, better mileage etc. Those results stay until it starts to get dirty again. I now use BG44K a couple times a year and when driven "easy" the cars do pretty good.
My 206k, 13 yr old Corolla, just got repeatable 38 mpg on a highway cruise nice and easy (no rush about 62 mph and cops EVERYWHERE). Not worth the cost and hassle of ticket etc. to speed. Normally I'm at about 30 mpg mix driving (with frequent 5500 rpm shifts) I haven't done BG in about 5 months.
Before the BG I was down to mid-upper 20's.
As part of your test, after a couple tanks, STOP using it and see how the following tanks are, calculated by total fill up gallons divided by miles driven. I mean total fill up! On my Corolla I can "top off" until filler neck is full and normally do. (The Sequoia holds almost 3 gallons more after the initial fuel shut off click at the pump). I ALWAYS fill up and write gallons and mileage in a book. I'm on my third book with details back to 1993. When I add the BG now it does not go up much as my injectors and other parts are clean and stay pretty good I'm presuming. I could probably add 3 oz everytank and won't see any increase (or decrease) consistently except for driving habits. 10 years ago I was able to repeat 41 mpg on a highway cruise with "stock" (read crappy traction, low rolling resistance) factory tires from NY to Carolina. The 38 was through hillier areas NY to MA and back a couple times with Q rated friction snow tires.
I'm not an engineer/chemist and don't believe that adding plain acetone to current fuel formulas would produce x% increase to everybody with out some nasty side effects.
I can tell you that "incompatible" caustic cleaners cause total CHAOS to the seals in our multi million dollar kettles. The basic high dollar lesson from the companies was "we didn't design the seals to work with that much of product X". We ARE however willing to send a rep from Germany to replace them for you at XXX cost. Lesson learned, "we" now use a different cleaner that is tested and approved.
After thinking about it the only way to increase mileage and make your car faster is to make it lighter. Rip out the passenger seats, strip your truck of all aftermarket accessories, take out your 100 lb sub box, run lighter rims, and only drive around with 1/4 tank of gas. Lol.
I do work with acetone on a regular basis in my chemisty lab and am well aware of it's corrosive properties.
My only incentive to adding this was that I knew that it most likely would clean out my injectors, and it seems as though it has. I did plan to stop using it to see if my millage would go back down, but I am still on my first tank, so it'll be awhile.
I would not spend over $20 for a gallon of this though and use it every time. I simply asked my chem prof. if I could use about 2oz. and she was cool with it. She said (in a very cool accent by the way!), "Of course you can; I don't blame you either considering gas prices. Let me know if it works; I think that it would" That's my chem prof. talking there, not me! She is an incredible lady and her knowledge of acetone and any other chemical is incredibly vast; so I had some added faith in trying this because of her.
I will let you all know of the outcome. I really do appreciate your input sequoiasoon, and I take those kind of helpful and knowledgable words to heart. So please anybody else reading this, it is not required for you to say anything "smart" or not helpful about this topic. I have heard it, and read it, all before in other posts.
Thanks agian.
__________________ David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Hellwig Anti-Sway Bar(removed)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
Have fun with that. But you missed one.....don't drive your truck
I don't drive my truck everyday, but my '04 Volvo S60R doesn't do much better than my Tundra. That probably has something to do with the way I drive its 300hp turbo engine. In fact it costs about the same to drive becuase I fill her up with 6 gallons of 100 octane at 6.10/gallon. I mix it with 91 octane (California gas) to get around 93-94 octane. The S60R really likes high octane. Its like crack for it's turbo.
I plan on taking off my stock fan and running electric fans and an underdrive pulley. Even though this is not proven I use all synthetic oils including Royal purple in the tranny It increased my milage from 15 MPG to 17 MPG when tested using the tripmeter. Also, I am going to upgrade the electrical system starting with spark plugs second upgrading the grounding wires, and then the spark to ground. Another thing to try is this stuff called Microlon. It is a one time additive that has been proven not only to lengthen the life of an engine but increase milage and reduce emmissions.
Even though its over $1000 in upgrades and will probably never get the cost back in fuel efficiency, its seems to me like a good thing to do.
Why do you assume that Toyota's engineers left out anthing to improve power and fuel consumption that was legal, drivable, and affordable?
Ken
I don't assume, but its been experience, that the engineers setup things upon a standard, not the best that can be achieved. So while they may have gotten the engine dialed in some, there is still room to tweak for better performance either with Power, or MPG.
A good example is the Front end alignment issue with the Sequoias, while they set things up within specs, it requires a good tweak of caster towards the Very extreme top edge of the standard to make it more stable and Less tire wear.
Here's another idea: Drive in the nude. The weight savings of not wearing clothes is good for about 1 mpg. Every little but helps.
Hehe.....and you can also take off the trailer hitch
I drive around with a lasso and try to hitch onto a diesel and kick it into neutral
not really. maybe if I had a sunroof
That's one way to car pool
...something that seems to have failed getting a mention...is that 9 times out of 10...you aren't going to get a boost in horsepower & mileage at the same time.. From what I know, almost everything out there is either not going to increase your mileage, or it's negatively going to effect it.
From everything I understand that best way in a truck to get decent mileage, is put either a tonneau cover or a camper shell on it (or drive with the tailgate down all the time.) Make sure your air filter and injectors are clean...
And stay off the throttle.
Everything that's going to increase your horsepower is pretty much not even noticeable unless you do everything all at once. Did I gain some horsepower when I pulled the stock exhaust off of Beth (see sig) and replaced it with a high performance Micron? Probably. Can I tell? Nope.
__________________ Lisa = 2003 Access-Cab Tundra SR5
C/R/C Tails, Clear Corners, Westin Black Ultimate Bull Bar, Toyota of Dallas Grille, PIAA 510 Ion Yellow Fogs, Putco LED Third Brake Light, Luverne Black Nerf Bars, Bilstein 5100's, Wheeler's AAL's, 285x75R16's on A.R. Trench wheels.
Horsepower is how fast you hit the wall.
Torque is how far you push the wall.
-Unknown
