Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 01-10-2003, 11:18 AM
BVS BVS is offline
Last Online: 04-28-2003 01:39 PM
BVS is on a distinguished road.
BVS's Photo Albums
Default Looking for Sand or Bridging ladders for off road use?
Looking for Tracmat's, sand ladders or Bridging ladders for off road use?
Does anyone know where I can get some of these http://www.gratingco.co.uk/tracmat.htm (in the U.S.)
Old 01-16-2003, 02:38 PM
BVS BVS is offline
BVS's Photo Albums
Ok, I found 2 places that will make them.
www.empirefiberglass.com/products_services.html
Here is the Email I received from Neil Baum
"Hi Bill,
We would have no problem suppling these to you or for you. The safe load on a 30 " span is 600lbs. with a 5 to 1 safety factor.
We would supply these in grit top finish., color green at $150 per pair, size 5' x 1' x 1 1/2" tk. and $120 for size 4' x1' x1 1/2" and shipping included (UPS Ground) for each pair.
Thanks,
Neil Baum"
I bought 1 set (two) of 5' x 1' x 1 1/2" tk. (1 section weighs about 19 lbs)
NOTE: I had to pay by check, they do not take Credit cards.
The specs for 1-1/2" Thick x 1-1/2" Square Mesh x 12" Wide
SPAN
Inches Break Point (lbs)
12 7800
18 5200
24 3900
30 3100
36 2600
42 2200
48 1700
_________________________________________________
After doing some math I figured I should have gone with the 2" Thick stuff. (I plan on using the 2" thick stuff for Bridging and the 1-1/2 stuff for sand ladders) So I tried www.amgrating.com They had a better price for the 2" stuff.
Jim Ho is the person you want to talk to for Amgrating.
Here is the Email I received from Jim Ho
"Bill,
For the 2" grating, If you can use 1' x 4' your price is $100.00 for two..
For 1' x 5', Your price is $150 for two.
Thanks,
Jim"
I bought 1 set of 5' x 1' x 2" tk (1 section weighs about 22.8 lbs very lightweight)
The specs for 2" Thick x 2" Square Mesh x 12" Wide
SPAN
36 7496
42 5143
48 4300
54 3323
60 2346
Note: The grating will Deflect (bend) long before it breaks. Check out there websites to see some pics. Then run a fork lift up on it.
So far I have only received the 1-1/2 stuff today. I will post pic's later. If you call or email them tell them you want grating for off road use.
This stuff works great if you get stuck! Just jack up your truck and lay the grating under the tire then lower the jack an go! (I use a Hi-lift jack in my front or rear receiver) Ok I'm done.
Old 01-30-2003, 06:38 PM
BVS BVS is offline
BVS's Photo Albums
Well it took some time but I finally got to use my Sand / Bridging ladders. Check them out under "My Photos" They are the Green Grid things Very cool for off roading.
Old 04-29-2004, 05:30 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
as of today, those prices are still good through amgrating. for reference to the vehicle, gawr rear is 3700# (the front is less), or about 1850# per wheel, which is still below the breaking strength (dunno about plastic deformation) of the [2"x2"x2"]x1'x5' piece. five feet is a long way...more than sufficient to cross large cracks and climb small ledges.
-s
GFX by FreedomEagle50
Manual Hubs
Old 06-16-2004, 10:32 AM
Images: 22
Default dang...
i shoulda ordered when i last posted, the guy i talked to at amgrating yesterday was the opposite of help--first thing he says when i mention theyre for offroad use is "we dont recommend that." then he goes on to say they only have 4'x12' sheets for sale, to the tune of over 500 bucks .
i'm going to try them again today, see if i get someone different, and i'm going to try the other place as well, i'll post what i find out.
*update* i spoke with both neil baum at empire, and collin at amgrating, both were very helpful. the pieces need to be located from scrap, they are willing to look, but scrap is the key, otherwise the entire sheet must be purchased.
*nuther update* collin at amgrating just called me back, here's what i've got...he located a section of 3'x7' scrap, i got that piece with cuts for 200 even. it'll be cut in half the long way, then trimmed to 5' long, i'm getting all four pieces--1.5'x5' fits perfectly widthwise in the bed, and provides some slop room for wider tires. the 2' long sections will come in handy as well, i'm sure...no more lugging around bits of 2x4. they are performing all the cutting and resin treatment, so they're ready to use as soon as they arrive. funny: he asked me if i cared if theyre bright orange .
both suppliers were very helpful, i think it would just depend on who has scrap available at the time. amgrating happened to have a perfect section of 2" scrap. also fwiw neil baum at empire remembered bill's order from over a year ago, i'd say that's a great argument for ordering there, also empire is east coast (NY), amgrating is west coast (CA), shipping might make a difference since even tho one ladder is ~20#, two plus smaller mats is ~60#.
-sean
Manual Hubs
Old 08-01-2004, 11:56 PM
Images: 22
after last week, those ladders are one of the best purchases i ever made for the truck . more later...
-sean
Manual Hubs
Old 08-11-2006, 07:46 PM
Dealer : Larry H. Miller Toyota
2006 Toyota 4Runner
Last Online: 12-30-2007 12:40 AM
jayheats is on a distinguished road.
jayheats's Photo Albums
Default Re: Sand or Bridging ladders for off road use.
Hey guys. Go to TERRA-TRAX.COM. I will sell them for $160 to any Tundrasoltuions member. These are 2" thick 48"x12". Go an see the pictures.
Thanks
JH
Old 08-17-2006, 05:13 PM
2006 Toyota 4Runner
Default Re: Looking for Sand or Bridging ladders for off road use?
Does anyone know where I can get some of these Bridging ladderss (in the U.S.)
You should look at www.terra-trax.com. These Sand Ladders are very durable. 2" thick with gritted traction surface. The can also be used as bridgeing ladders.
Old 02-10-2007, 01:22 PM
Dealer : West Ashley Toyota
Last Online: 01-27-2008 05:53 PM
your drinking buddy is on a distinguished road.
your drinking buddy's Photo Albums
-sean
What do you think of them now?
Old 03-25-2007, 02:46 AM
Dealer : Canyon Creek Toyota
1995 Toyota Tacoma
Last Online: 03-25-2007 02:48 AM
doorango is on a distinguished road.
doorango's Photo Albums
Hello. New member found this thread on google. Curious how the terrra trax ladders work in rocky trails with a 5-6000 lb rig.
Old 01-24-2008, 03:21 PM
Last Online: 04-02-2009 01:48 AM
TUNDRA786 is on a distinguished road.
TUNDRA786's Photo Albums
Whats the best bang for your buck? Anyone know anything i can from Home Depot???
I read somewhere someone bought a set for 20 bucks at an Army Surplus store. I dont want to spend much. I just want something to use if i get stuck in mud or sand. Wood is usually slippery. any Ideas????
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
Old 03-11-2009, 04:32 PM
Sand Ladder
This message has been deleted by DevinSixtySeven. Reason: Sorry Brian, you need a vendor agreement to post like this.
« Raps | crutchfield »
