Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 06-16-2004, 01:06 PM
Dealer : Northridge Toyota
2006 Toyota Tacoma
Last Online: 11-11-2008 04:13 PM
DeMello OR is on a distinguished road.
DeMello OR's Photo Albums
Default What would you do to your truck if money was no object?
Sliders?
Bumpers?
coil overs?
bed bars?
long travel?
solid axle swap?
tires and wheels?
Old 06-16-2004, 02:58 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Default that's a long list!
to that question add "...and not a daily driver", cuz if i could, i'd somehow get portalled axles underneath.
anyway, realistically, a true high pinion ford 9" front and rear, full float, discs, gmc d60 kingpin outers in front, double shear uniballed leaves in the rear so i can keep load capacity, coil sprung front for flex...
...finish boxing the frame, add another crossmember where the stubs are toward the front (you'll see what i mean...) to brace the frame, skid plates rail to rail, countersunk bolts on the bottom, or protect the bolts by wrapping the plates and putting the bolts in the side, wheel to wheel sliders braced to the frame where possible and appropriate (linked near/outside crossmembers), skid plate equipped high clearance rear bumper (same as joe's, actually), similar front bumper with a 10k or 12k winch and synth line.
snorkel. dual batteries mounted in center of rear seat, right side of the seat trimmed to match the left, okole covers to keep the crap off ( i've already measured, this will work).
shock hoop in the rear, a-framed shocks. bed utility carrier secured to the rearward four bed bolts, for a spare tire, a couple jerry cans, hi lift & chain, bridging ladders, shovel, ax. rack with a few lights for the top of the can-bak. undercarriage lights. cab halo for some low-prof lights and things like cell and cb antennae.
internal roll cage...compatible with a sunroof . speedglass windshield. doors that dont rattle when theyre rolled down. tcase brace. 2nd tcase.
strategically applied line-x. hole and scoop in hood linked to airbox turned sideways, closeable for water crossings.
beadlocks and 37" krawlers for the trail, 37" a/t and no locks for the road.
some of that is currently and cheaply attainable...the rest, some aftermarket support would be great...a few of those things are already on order .
-sean
GFX by FreedomEagle50
Manual Hubs
Old 06-16-2004, 03:56 PM
Last Online: 11-08-2004 12:54 PM
atrain is on a distinguished road.
atrain's Photo Albums
I'd go with Long travel up front, fox shocks all the way around. Rear shocks would be hooped into the bed. The frame and bed would be reinforced. Supercharger w/ blueprinted engine, ported polished and gone through. 37" baja TA's mounted on beadlocks. ARB locker in my one and only diff. Custom fabbed Front and rear bumpers, with winch on front. Fender flares and Roll Cage.
Just to start.
_________________________________
"I feel sorry for those people who don't drink.
When they wake up in the morning,
that's as good as they're going to feel all day."
Frank Sinatra
Old 06-16-2004, 04:08 PM
Lalo's Avatar
TEAM SCT
Dealer : Kearny Mesa Toyota Scion
2000 Toyota Tundra,
- Other - 1998 VW PASSAT 1.8T
Last Online: 11-17-2009 12:29 PM
Lalo is on a distinguished road.
Send a message via AIM to Lalo Lalo's Photo Albums
Custom Long travel
30"+ travel front and rear with AWD
carbon fiber one piece hood/fenders, and bedsides
full tube frame and internal roll cage/engine cage
50 gallon desert tank
twin turbo v8 with 700+hp
and the list goes on and on...
www.SoCalTundras.com
Old 06-16-2004, 04:36 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 11:52 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
Smile
All I'd want is a new paint job with something that doesn't chip so bad. Pretty simple want huh? Other than that I'm happy with what I have.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 06-16-2004, 05:08 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Shorten the frame in the rear, move the rear axle forward about 12", bob the bed, full exo skelton(bumper to bumper), volvo portal axles f/r, sway away dual rate coilovers at all four corners, marlin crawler, beadlock rims with some 37"+ BFG krawlers, send engine to TRD to have whatever modifications they can do for max power and low end torque, fuel cell, high output alternator to power dual batteries for winches in the back and rear, underhood air compressor, ready welder and whatever electronics I need. For now, that's what I can think of.
Mike
http://dyogim.blogspot.com
Old 06-16-2004, 06:02 PM
atrdnut's Avatar
2003 Toyota Tundra
Last Online: 11-16-2009 11:53 AM
atrdnut is on a distinguished road.
Send a message via AIM to atrdnut atrdnut's Photo Albums
I'd find a way to make my truck do a back-flip. No one would even dare to think of such an awesome feat. *PATENT PENDING*
Oh, maybe a winshield that was rock-chip-resistant too.
-Austin
2003 Toyota Tundra SR5 TRD Sport
Old 06-16-2004, 06:38 PM
shelbix2020's Avatar
Dealer : South Coast Toyota Scion
2002 Toyota Tundra
Last Online: 04-09-2008 11:26 PM
shelbix2020 is on a distinguished road.
Send a message via AIM to shelbix2020 shelbix2020's Photo Albums
Sell it and buy a Shelby Cobra
Originally Posted by HuskerTundra
Shelby is right. Chicks dig purple. Buddy of mine has a PURPLE tundra , and he is always gettin compliments from ladies at school on his truck.
Old 06-16-2004, 08:26 PM
wylcat's Avatar
DIRT BAG
Dealer : Sparks Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 11-15-2009 09:01 PM
wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence.
wylcat's Photo Albums
sounds like you want a taco with a V8
HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Old 06-16-2004, 10:18 PM
matttom's Avatar
Toyota Lifer
Dealer : Atlantic Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 11-13-2009 05:01 PM
matttom is on a distinguished road.
Send a message via AIM to matttom matttom's Photo Albums
I would do everything SCDTRD did to his
2002 SR5 AccessCab 4x4 TRD
Performance: Borla cat-back, K&N FIPK, Magnetic oil plug, 265/75/16 BFG AT, 16" Rage wheels, Tow package,TRD AAL
Appearance: Molly IS Grille, Sportmaster Tonnau, Clear corner and tail lights, IS mirror covers, Color keyed tailgate handle, Debadged, Window tint, VIN etched glass, Bugdeflector, Ventshades, Stepsheilds,Window Latch upgrade
System: Sony headunit,Sirius s50, 200w Kenwood amp, 10" Bazooka, Sony 10-disc, Infinity 6.5" speakers.
Still sitting in my basement:New IS bumper, Cornfed spacers
2000 4RunnerSR5 4x4, Pro Comp stainless step bars, TRD drop in, Ventvisors and deflector.
2006 Kegerator stocked with Blue Moon Belgian White
New York Mets 2007 The greatest choke job in MLB history!!!!
New York Mets 2008 Blew it again!
New York Mets 2009 They need obamacare
Old 06-16-2004, 10:29 PM
lelandstanford's Avatar
2005 Toyota Tacoma
Last Online: Yesterday 11:52 AM
lelandstanford is on a distinguished road.
lelandstanford's Photo Albums
If money is no object then why bother modify the truck?
I'll just buy something I like such as this:
http://www.mercedes-benz.com/omb/d/e...nimog/u500.htm
2005 Tacoma AC 2WD 2.7L 5M
Old 06-16-2004, 10:56 PM
Images: 22
not quite the same
but i'll take the axles
Manual Hubs
Old 06-16-2004, 11:19 PM
Dealer : Poway Toyota
2004 Toyota Tundra
Last Online: 03-06-2009 10:15 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida dezert_rida's Photo Albums
If money was no object, first id buy a house to park it in.
Next, id make my own 4130 uniballed arms upper and lower 5-7" wider per side, with upgraded spindles, dual rate coilovers, bypasses and air bumps up front. Id make my own engine cage to mount all that plus the glass, radiator, condensor AT cooler lights and so on. Then id gusset up the rear, put in lower gears and locker, 35s, link the back end, cage it up with nice seats, coilovers and bypasses and air bumps on the back end. I make my own bumpers as well.
Once every last detail is setout and it is complete, id need a double cab Tundra with a blower to pull it on my new trailer!!!!!!! Thats approaching GVWR though so i may have to lower my self esteem and buy a GM 2500 with a duramax(I hate Chevy but id take that over a Powerstroke or Cummins).
Old 06-18-2004, 01:26 AM
2006 Toyota Tacoma
You guys are crazy! Back flip?
Old 06-18-2004, 05:33 AM
fooddude's Avatar
Dealer : Power Toyota Irvine
Last Online: 07-01-2006 03:36 PM
fooddude is on a distinguished road.
fooddude's Photo Albums
Turn it into a trophy truck. Center mounted front a-arms and center mount independent rear suspension with all the other TT stuff. Basically like Ironman Stewart's beast but with carpet, almost stock interior, no paint scheme, stock looking, and more DDable.
Get down, Do you?
