Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
Old 08-23-2005, 08:21 AM
pistolpete's Avatar
Dealer : Crystal Toyota
2004 Toyota Tundra 4X4 SR5 Double Cab
Last Online: Today 03:26 PM
Images: 163
pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all.
pistolpete's Photo Albums
Default TRACRAC stake pocket expansion block question?
Sorry folk I also posted this in the interior exterior forum but wasn't getting any repsonses.......
I have a quick question for those that use any type of expansion blocks for tie downs, bed rails, TRACRAC, etc...I was test fitting the TRACRAC yesterday and when tightening down the rails the expansion block rises just slightly up out of the stake pocket on the outermost portion where the truckbed rail slopes away. IS this normal or should the expansion block hook completely under the stakepocket?? there are only three sides that have a lip and the fourth side (on the outmost part if the bedrail is a solid vertical wall with no lip for the block to slip under. Just wondering as I can tighten down the block enough to prevent removal but can see a 1/8"-1/4" of the block between the plastic shim and the bedrail.
Those with RETRAX....my initial test fit indicated it does NOT appear I have to cut out any of the RETRAX rail around the stake pocket! Can leave the RETRAX rail intact as it only covers 1/2 the stake pocket and the bolt skirts right around the rail...... However, I may have to cut some off the plastic shim TRACRAC gives you to keep it off the RETRAX rail and prevent it from adding even more height to the inside edge....I will try and get pics of the test fit on the single rail I did...(had to stop this weekend as we had a emergency with our new puppy as she hurt her foot real bad (bad sprain-caught her foot between bars in her crate! ) Vet visit today confrimed sprain/brusie but luckily no broken bones! Probably wont get to the new TRACRAC till the weekend now
Pistol Pete
#1 COLTS fan!!!!
2004 Toyota Tundra Double Cab 4X4 (7844A), Phantom Grey Pearl, All weather guard package, fog lamps,keyless entry, 17" AA wheels, towing package, color-keyed overfenders, 4.1mm Limited Slip Diffy, Delux 3-in-1 JBL stereo, privacy glass, floor mats with sill protectors, bed extender
MODS- Line-X, Retrax, Onki nerf boards (part #328078), Wade vent visors (part #88401) , TracRac (rail # OL-21609), Ultimate Fly Fishing Rod transporter, Spin Caster Rod holder in bed, Recon bedlights fully adjustable w/"nightvision", HitchSafe, Weathertech floor liners (part #46030-1&2, grey), debadged, visors destickered, rear window stop disabled, dynolock/PL8500 power tailgate lock, tailgate protector mod with detachable floormat, Stebel Nautilus Compact Truck Air horn (300Hz), quick fist flashlight holder (all in photo gallery).....more custom suprises on the way!!
New members from the MidAtlantic (PA,OH,WV,VA,MD,DE,NY,NJ,DC) don't forget to check into the MidAtlantic Forum and introduce yourself!!!
Old 09-02-2005, 12:54 PM
Dealer : Fremont Toyota Scion
2002 Toyota Tundra
Last Online: Today 11:09 AM
rlehan is on a distinguished road.
rlehan's Photo Albums
I installed the TracRac on my truck yesterday. I sandwiched the Retrax flange between the plastic shim and the TracRac rail. I have a drop in bedliner and have plastic caps on all the rails. I had to use the rubber shims to level the TracRac rails. I put the rubber shims on the outer edge between the plastic shims and the TracRac rails.It was a little tricky but I am happy with the results. The TracRac is very stable and slides smoothly. I will take some pictures and post them when I get a chance.
Rick
Black 2002 Limited 4x4
Mods: TRD Supercharger, Boost Guage, Unichip, Clifford AvantGuard 4 Alarm/Remote Start system, Auto Dimming mirror w/compass & temp, Sequoia Power Antenna, Retrax bed cover, Donahoe long travel coilovers, Total Chaos Uniball UCA, Helo Black Maxx 6 wheels w/ 265/70R 16 Michelin LTX/MS tires, Ivan Stewart front bumper cover, TRD headers, TRD dual exhaust, factory LSD, Total Chaos urethane steering rack bushings, Wheelers urethane front swaybar bushings, Helwig rear antisway bar, Goodyear Gatorback serpentine belt, Fumoto engine oil drain valve,Denso IK22 Iridum spark plugs, Eclipse AVN2454 AM/FM/CD/DVD/Navigation system w/ color backup camera, SilverStar headlights and fog lights, WeatherTec in-channel wind/rain deflectors, Ventshade door sill protectors, Toyota hood protector, TracRac sliding rack system with cantilever extension, IPOD integrated with Eclipse AVN2454, PopnLock electric tailgate lock, Sequoia electric condenser fan, Viair 440P portable compressor, ORS manual hub conversion w/Aisin hubs, StubbsWelding SKO rock sliders, 60" hi-lift extreme jack with slider adapter, Odyssey PC1700MJT battery
Coming hopefully - Warn 9.5ti multi-mount transportable winch, ARB lockers front and rear, 4.30 gears
TRACRAC stake pocket expansion blocks pistolpete Interior & Exterior 14 01-23-2006 02:38 PM
Looking For Stake Pocket Tie-Down Rings Xtrema Interior & Exterior 14 01-12-2006 09:25 AM
Stake Pocket Rack - Rear Only Boston Tundra Interior & Exterior 0 07-25-2005 05:12 PM
Stake Pocket Tiedowns or Rails Poetsfolly Interior & Exterior 56 03-16-2005 02:25 AM
Stake pocket tie downs? hsvhobbit Interior & Exterior 3 06-22-2003 09:00 AM
